Mirror - Deafult Settings - Not deleting files from the right
portableanswers
Hello, please see attached screenshot.
The left explorer is from my C drive. The right is from the backup drive.
I used Mirror default settings for the second time after my first backup a few weeks ago.
As you can see, files that were deleted (by me) from the left are not being deleted from the right.
There must be a gap in my understanding. I am looking through the documentation and tutorials.
Thank you.
I will assume your explorer listings are showing the status *after* running the second FFS Sync.
If not, then first run an FFS Compare *and* Sync.
If yes, run an FFS Compare and try to find the DisplayFusionSetup-9.1.exe file and the FFS proposed sync action. If necessary, make all Compare result Categories visible (by clicking the icons mid-below the Compare results.
If you can not find the ...9.1.exe file there, you may have, intentionally or unintentionally, added DisplayFusionSetup-9.1.exe to your Exclude Filter. You can check this via the funnel-icon (F7) mid-above the left-right pair definition.
