Cannot find file .ffs_batch
harish88
I created the ffs batch file but then changed my mind and deleted it. However, I keep getting the error message "Cannot find file .ffs_batch" for obvious reasons. How can I delete the batch job itself? Thank you!
It seems you have created a scheduled task to launch the sync that tries to open your .ffs_batch file, or that you have put a command to launch that file in your autostart folder.
Depending on where you defined that task, you should remove it there.
harish88
Thanks! I have created a scheduled task by saving the batch job from Freefile Sync, pulling it into RealTime Sync (and clicking Start). I guess my question is, how do I delete that? I don't see any menu items to let me do that.
Option1:
Restart your PC. This will kill and not restart the manually started RTS task.
Option2:
Start your task manager, identify the RTS task and kill it.
harish88
Thanks!
