Using v3.12 in batch mode, I get a message saying "Info: Nothing to
synchronize according to configuration" even though it has just synchronized
some files - and an inspection shows that the synchronization seems to be
happening fine. I have only noticed this incorrect message since upgrading to
3.12 from a recent earlier version. So although not a critical bug, it is a
disconcerting message.
Has anyone else noticed this?
Nothing to Sync Reported in Error
Indeed a small bug. Thanks for the info, fixed for next release!
-Zenju
-Zenju
