Hey guys,
our FFS started to act not normal today. Almost every job ran into the LIBSSH2_FX_FAILURE [libssh2_sftp_rename]. So I stopped every job and searched a solution for the problem but I can't find a fix. I manually started a job again and it loaded the ffs_batch. I continued to start the sync (mirror) and immediately the error came up.
The jobs worked days before when they started and nothing changed inbetween. The user has read and write rights, which worked before.
Any Ideas?
Libssh2_sftp_rename Error
EDIT: This problematic happens with activated versioning. The versioning should only move the files from one folder to another. Both folder are shared folders on synologys. And the permissions are the same.
I deactivated the versioning and the job works again.
For anyone having this issue. I've found disabling the tmp temporary file option in the tools section to get rid of this. I has resulted in more transfers timing out but it's better than not working at all.
