Hello All,
What I am trying to do.
Synchronise a partition on windows with my external drive using Mirror option.
What is the problem.
The partition has my OneDrive mapped in it. Some folders are set as Keep Locally, some are on the cloud only. When I synchronise, FreeFileSync downloads the folders from the cloud and then synchronises. I don't want it to download and synchronise folders in the cloud but only the ones kept locally.
How do I do this?
Syncing and OneDrive
You can't do this. Unless, you are only saving folder(s) locally, then you could use filters to exclude/include what you don't/do want. If you are syncing files from various location in OneDrive, this would be complex
