Scrambled UI after folder comparison
carbone
Some UI issues on Linux after folder comparison and sync. See attachment.
I've deleted only the Drag&Drop and Drag text in texboxes but the rest is "as is".
Try Reset Layout in the FFS GUI under Tools
Which Linux variant and version is this?
carbone
Arch Linux with KDE Plasma.
bgstack15
For a nuclear option, if you're not picky about historical settings, you could move or modify ~/.config/FreeFileSync/GlobalSettings.xml.
jacanestro
Same problem here with Window latest version.
Nueva imagen de mapa de bits.jpg (376.42 KiB) Viewed 3662 times
Nueva imagen de mapa de bits.jpg jacanestro, 29 Oct 2022, 07:41
Not quite the same...Restart your computer
carbone
Not quite the same...Restart your computer xCSxXenon, 30 Oct 2022, 15:14
How's possible that not restarting the computer causes this graphical bug, maybe some Windows update that is partially applied?
How's possible that not restarting the computer causes this graphical bug, maybe some Windows update that is partially applied? carbone, 30 Oct 2022, 16:39
What? No? Restarting something is just the first troubleshooting step for every problem ever
This doesn't look scrambled.
This doesn't look scrambled. Zenju, 30 Oct 2022, 18:38
I assumed it was the white box in the sessions box, but that may just be an edit for privacy
carbone
I assumed it was the white box in the sessions box, but that may just be an edit for privacy xCSxXenon, 30 Oct 2022, 18:43
Yes it has privacy edits you have to look at top portion.
Yes it has privacy edits you have to look at top portion. carbone, 30 Oct 2022, 20:02
Looks exactly like mine does
