viewing excluded files
bernso
Hi everybody
Is there a way to see the excluded files in the dual file list ? I did not find a way to see those either together with the other files selected or alone. I think there should be a button on the bottm line together with the other 2 buttons selecting = or <>
Thanks in advance
FFS doesn't scan excluded files at all so they cant be viewed after running a compare.
...unless the exclusion is applied *after* comparison, in which case excluded files are included in the list. FFS doesn't throw away information it already has (but has to during comparison for performance).
