As the subject says, i need a function in the donation version where i can choose reboot after finishing the batch in case that i daily reboot the server and before that happend i want to do a backup of all files.
I could do that on my way with my windows automation, but the faster and better way would be that it is included in ffs.
So i would be happy if it can be added in the near future.
Greetings from Berlin
Save batchfile under windows with reboot option
Not quite sure if this will pan out, but give it a try:
(Also unsure if that will cause a UAC prompt?)
Synchronization Settings -> Run command: On completion: -> shutdown.exe /r
That is how we use it actual, but it would be for other users more comfortable if it is chooseable due to the dropdown menu like shutdown actual is.
