I just downloaded the latest version of FFS after a reformat. I used task scheduler (windows 10) to automatically run the same batch file I've been using for years. Everything seems to be working fine but for some reason Real Time Sync is now running in the taskbar. I don't want Real Time Sync to run at all, but I can't seem to find any settings to prevent this from happening. Is this a new feature of the latest versions of Free File Sync? Is there any way to disable Real Time Sync from running when I schedule a batch?
EDIT: I can shut down real time sync from the task bar but I would rather it not be there in the first place. It doesn't appear until my batch runs, but it remains after the job is finished.
RTS running after scheduled batch?
What command is your task running? Sounds like you are running a ffs_real in the task, which results in what you are describing.
