hello, the mail notification always starts after the final command. How can I send the email BEFORE the final command?
If it is true that with the final command can turn off the coomputer, it is also true that the notification mail will not start!
Send the notification email AFTER executing the final command
You can make the shutdown command wait a user-defined amount of time before running
Thanks for your answer, I should disable the network card (netsh interface set interface Ethernet disable).
But I see from the logs that first executes the command ... or launches it and goes on without waiting for it to end?
thank you
thank you
Hi, I've configured the pause before disabling the network adapter but the email notification do not start because start after the command.
FIX REQUEST 😁: execute email notification AFTER the "final" command execution
