Folder Structure and ONLY ONE file type
markiloon
FFS 11.24 is awesome!!! super great work!!! many thanks!!!
a question though:
how to sync the "Folder Structure and ONLY ONE file type"?
please help!
many thanks in advance!!
Marki.
markiloon
I think i know now.
First, sync folder structure by exclude *:
Then, sync that file type by include *.abc
Marki.
If the folder structure is only needed/relevant for the *.abc type files, there is no need to first sync the folder structure.
FFS will sync the *.abc type files in their folder structure (relative to the left and right base location) and create the folder structure as necessary to store the *.abc files.
Only (sub)folder trees that do not comprise any *.abc type files will then not be created.
markiloon
sorry i was not clear enough!! by 'folder structure' i meant actually ALL folders.
anyway, many thanks for the reply!!
Marki.
