FFS macOS 11.24 shows up on the Menu Bar ONLY after switching desktops in 'Spaces' …
It was NOT like that with older versions.
11.24 macOS — some interference with Menu Bar
Does this still occur in FFS 11.25 (that I'll be releasing later today).
FFS 11.25 is still not fixed.
MacBook Pro 16-inch (M1Pro,2019) macOS 12.5.1 Monterey
Hi, thanks very much for replying … ;)
I can attest to what Pajerow said, error persists in 11.25.
However, I hope this won't be too much of a problem, and that syncing will work as it should … ;)
Here's another observation; maybe this could be helpful:
Yesterday, upon realising the bug, I went back to 11.23, and lo and behold, there was the same bug, i.e. only after switching and switching back desktops in Spaces got FFS registered on the Menu Bar.
P.S.
Just in case this is relevant:
I installed FFS for ONE USER ONLY; and in a user account with NO ADMIN PRIVILEGES.
P.S.
The display is just abnormal, and there seems to be no problem with the original function of the application.
Sorry...
Because it is a machine translation, the expression may be strange.
Sorry...
@Pajerow: Is this bug also on FFS 11.23 as fofas described?
As expected, I can't reproduce this GUI glitch :(
I haven't checked the version back, but there should have been no problems up to 11.23.
The menu bar is not displayed only immediately after the application starts.
Once you activate another application and activate FFS again, the menu bar will appear.
I see there is some conflict with wxWidgets also calling [NSApp activateIgnoringOtherApps: YES]; on startup:
https://github.com/wxWidgets/wxWidgets/blob/2545cf5b8dd667a9cfefd3315c8fe791de386eba/src/osx/cocoa/utils.mm#L78
FFS changed from NSApplicationActivationPolicyProhibited to NSApplicationActivationPolicyAccessory, so wxWidgets is also calling "activateIgnoringOtherApps", but way too early, before FFS even has created the menu bar.
Maybe the menu is only enabled if existing during the *first* activation attempt? That would explain things.
Here's a test version with wxWidgets' interference disabled: https://www.mediafire.com/file/x0fxk2stllmaadq/FreeFileSync_11.26_beta_macOS.zip
I checked with FFS 11.26 beta.
This issue did not occur.
Please release the official version (donation version).
Awesome, thanks for confirming!
Is there any way to get the old donation version?
Only if you saved the installers. Otherwise, noIs there any way to get the old donation version? Pajerow, 04 Sep 2022, 00:27
I got it. Thank you.Only if you saved the installers. Otherwise, no xCSxXenon, 04 Sep 2022, 14:06
It was fixed in FFS 11.25 September 2nd version.
I did not notice.
Reinstalling FFS 11.25 today fixed this issue.
Or maybe the Monterey 12.6 update fixed it?
I did not notice.
