Any Way of Resetting the Directory Selection Box?
sjmarano1
Is there any way to reset (erase) the directory selection listings that appear in the scroll boxes when you click the DOWN ARROWs immediately to the left of the BROWSE buttons? These selection boxes are very convenient, but in my case they are filled with directory listings which no longer exist. It would be great if it were possible to clean them out.
blues12
If you don't mind working under the hood:
Close FFS and edit the GlobalSettings.xml
There you have entries for FolderHistoryLeft and Right
Mouse-hovering over an item + pressing DEL key should work.
sjmarano1
To Stefan and Zenju, thanks very much. Both of your tips work!
rsherard
