I try to describe the problem I've got during syncing with FFS between my laptop and my phone. Pc is Windows11 and mobile is Xiomi Android 10. I try to mirror a folder FROM pc TO a folder on mobile. The comparison works fine, and FFS can write without any problem to the mobile internal storage, but it can't write to the mobile SD card. I post a screenshot of the error.
The file the screenshot is talking about is, for example, a excel file (xls) but it seems there's a problem with a TMP file (???).
Before writing here I've found this post ( viewtopic.php?t=7956&p=27359 ) which suggests this operation:
sfc /scannow
dism /online /cleanup-image /restorehealth
sfc /scannow
I've done it without any result, FFS still can't write on SD card throught the phone.
With Windows Explorer I can do everythink i want via MTP on the sd card ( so i don't think is a Windows problem)
Any idea?
MTP issue from PC to SD Android Phone
Thank you so much!!!! Solved with a simple flag ;-)
Mauri
Mauri
