Hi
I've just downloaded and installed FreeFileSync, but can't set it up, as I can't create a new configuration file. as the menu 'NEW' and 'SAVE' options are greyed out.
What do i need to to set up a new Sync?
thanks
New Configuration greyed out
See attachment for reference
You are already on a blank template. You can start a new one or save a config if there is no config yet
