Donation edition Installkey failure
Just made the donation; got do download the two files, but the Installkey file is apparently damaged, so installation fails. Now what?
Got the donationversion after donation; downloaded the two files, but the Installkey-file is apparently damaged, for installation is terminated. Now what? Another donation? :-)
OS?
Zip or installer?
Did you try both?
What is the exact error message that you get?
Zip or installer?
Did you try both?
OS is Linux LMDE 5.
Downloads/FreeFileSync_11.25_[Donation_Edition]_Linux.zip
Unpacked it into: Downloads/FreeFileSync_11.25_[Donation_Edition]_Install.run
Then: "Error: could not find /home/Downloads/FreeFileSync_11.25_[Donation_Edition]_Install.key
<Press a key>"
Pressed the key and nothing happened.
<Press a key>"
