Hello
Apologies if there is an obvious answer to this:
I am using FreeFilsync v3.11 between two pcs (Win 7 x64 and Win XP Prof 32bit)
via a USB stick.
When I autosync, changed and new files are identified correctly; but other
files that have not been changed have a 1 hour offset when compared, which
results in them all being unnecessarily copied (updated) too, slowing down the
sync process.
Any advice as to what is happening?
thanks
File synch 1 hour offset?
Probably the same issue as discussed here: viewtopic.php?t=967
Thanks for the quick reply and info.
Yes, working fine now, needed a full round of synching.
A very nice piece of software.
