I have a NAS that I sync with my laptop that currently, for a series of hw problems, is not online. Not a big problem because the laptop side is currently not touched.
I'm disturbed by the red "last sync" number, but I don't want to remove the session from the list hoping the connection problem will be solved soon.
Is it possible to hide the entry in the list on the left or at least remove the last sync number there?
Thanks!
mario
Hide session in list. Possible?
You can hide the configuration entry and re-add it later
I see, right-click, Hide, but how do you un-hide it?
File -> Open
Thanks a lot! I forgot about the right click...
