when the files of both sides both change
Can you set the files of both sides to be saved at the same time instead of popping up an error?
Yes, you have to set custom sync settings. All of the presets are set to just leave both sides as is and warn you
But the custom sync settings also don't have the option to keep both filesYes, you have to set custom sync settings. All of the presets are set to just leave both sides as is and warn you xCSxXenon, 14 Oct 2022, 16:00
Ah, I see...
If you want to keep both versions in their locations, just exclude them from the sync?
