Save sync files in separate folder
sakon
Hello all,
does anybody know a way how to create a separate folder in where all files will be copied which are in synchronization task.
I don’t want to keep the deleted version, I need to have a folder where I can see later which version I did update.
Many thanks in advance.
sakon
sakon
I am one step further.
If you select all files after comparation you can right click -- > copy to
This works fine so far, if anybody knows a way to include this in the automatic task. Like versioning with deleted files.
Feel free to let me know.
sakon
