recicly bin
anmir55
When I want to synchronize a network directory this message appears, how can I solve it:
he recycle bin is not available for "\xxxx\xxx\".
ERROR PATH NOT FOUND: The system cannot find the specified path..
[RecycleBinManager:WillRecycle]
Ignore and delete permanently each have recycle bin is unavailable error
Change the sync setting to delete permanently instead of sending to Recycle Bin
anmir55
Thank you
stp8193
Similar situation/error but would prefer to send to Recycle Bin. Is there a way to register the recycle bin path?
If you are getting the same error, then you can't use recycle bin. The error is saying that there is no recycle bin available, which is typical of some network shares
stp8193
Not even a registry edit? Or a way to redirect them to another folder? Thanks
If you are getting the same error, then you can't use recycle bin. xCSxXenon, 09 Mar 2023, 20:32
Or a way to redirect them to another folder? stp8193, 09 Mar 2023, 23:51
Select "Versioning" in sync settings instead of recycle bin.
Select "Versioning" in sync settings instead of recycle bin. Zenju, 10 Mar 2023, 18:06
This can work. It lacks a "restore" option and dumps everything in one large folder so it could be hard to know where a restored version needs to go
