about File Versioning and empty folders ....
pisa
HI,
about your very nice freefilesync i have this question
Keep multiple versions of old files
With naming convention Time stamp [Folder]
this wok only for files, right?
i you have in the original folder a subfolber empty, this is copied in the right
now if you delete this empty sub-folder in the left, this is delete in the right ok, but a versioning copy is not execute, this is rigtht? the versioning work only for files...
thanks!
Good question actually! Try it out and report back, it would be interesting to know
pisa
i noticed this because i tried, but i don't know if there is any option to manage this choice
There is no option, it just does what it does
pisa
maybe it would also be right to save the structure of empty directories, right?
pisa
this question appear not interesting!
