Hello Zenju,
In your sources (Bugs.txt) you mention a bug in curl referencing https://github.com/curl/curl/issues/1455 & https://github.com/curl/curl/pull/1470
As a courtesy since the commits weren't squashed, I took your PR, refreshed it and created https://github.com/curl/curl/pull/9758
Upstream now suggests some changes. Would you please do them so that the long standing issue you discovered and tried to get fixed by that time can be merged in the next curl version?
Rgds
Your curl patch for the bug you mention in Bugs.txt
Thanks! But I don't have time for this. Feel free to take over. Regarding FreeFilesync, only this part here is relevant: https://github.com/curl/curl/pull/1470/files#diff-364cd314af9e1952095cf04896ec290a75f7c67527fb7b621895436142be5977R1970
Hopefully you will find some time to fix it in future.
The URL you reference is already used and integrated into the PR https://github.com/curl/curl/pull/9758
You just have to fix the last things of that PR. I can squash your commits if this is the point, but can't do more, sorry.
