Hello I was wondering if there is a way to update your files from left to right and after the update (from left to right) delete the files that you already updated from the left side?
Example...
Left side has Doc1 - Right side nothing.
then you update (Sync)
Left side has Doc 1 - Right side has Doc1
After the update how to delete the file on the left side but keeping the file on the right.
Left side nothing - Right side has Doc1
Is this possible?
How to update then delete updated files
