Need to sync a folder
Will FreeFileSYnc do the same job as robocopy (or similar copy programs) in syncing a file from one drive to another? i.e. will it transfer all the files?
That is the whole point of the program.
How it goes about it, specifically, all depends on the settings you choose to set.
So read the Help. Then test, ahead of time, & verify that what you want to do is what is being done.
