Add Cloud drives to FreeFileSync
JorgeCarousel
Is it possible to sync folders from a S3 bucket for example to a local drive? if not, there is a suggestion for FreeFileSync.
Thank you.
Raki72
I would also appreciate it to be able to sync with my Microsoft Onedrive.
Thanks!
shalbFFS
One more for Microsoft OneDrive
shalbFFS
@xCSxXenon, that was helpful as it remindend me of a proceeding I already had made some years ago, using a symlink to my folder to be synced to OneDrive. You achieve that by using the built in feature of mklink in Windows 10, like described here:
https://winbuzzer.com/2020/07/24/how-to-onedrive-folder-sync-any-directory-via-mklink-xcxwbt/
