Hi! I'm new to using this incredible software and so far I'm impressed.
I need help with something I've been wondering about and can't get it to work, even used the search option on this forum. Is it possible to sync only specific files without the folder structure?
Example 1: picture album that has lots of folders ("x year" folders with "x month" folders inside), so when I try to sync from that folder to an external drive it only sends the .jpg and .mp4 files, without the folder hierarchy, so the result would be just 1 folder with all the pictures and videos.
Example 2: different folders that have some documents that I require in just one folder in my Android phone, so when I do the sync process it only refreshes the files to my Android folder and not copy them again (including the folder tree), I just need to refresh the files.
Thank you so much.
Sync ONLY files but not folder tree?
