I am trying to sync a folder on my laptop to a folder on another computer on
my network, but I am getting an error from RealTimeSync after FreeFileSync
finishes syncing the first time. The error is "Could not register device
removal notifications: Windows Error Code 120: This function is not supported
on this system."
I am using version 3.9.
The OS on my laptop is Windows 7 x64, the OS of the other computer is Kubuntu
10.04 x64.
The folder being sync'd to is being shared using Samba.
Any help would be appreciated.
RTS Could not register device removal notific
The feature of detecting user requests for device removal probably is not
relevant for your Samba share (usecase are external usb sticks and hard
disks).
Does using RealtimeSync work with Samba at all? You can try this by using
v3.8, which doesn't have this new feature mentioned above.
disks).
3.8 seems to work, is it possible to disable registering for device removal
notifications in 3.9?
Yes, it will be fixed with v3.10
