I am constantly getting this error message when trying to sync:
"Cannot move file
"E:\ArchiMED4\DBImages\10039774\DB1~0ca0.ffs_tmp" to
"E:\ArchiMED4\DBImages\10039774\DB1.SIM".
ERROR_ALREADY_EXISTS: Cannot create a file when that file already exists. [MoveFileEx]"
I tried looking at the older threads but they suggest this issue was fixed, but I am using the latest 11.27 64 bit Windows version.
I've been having this issue for a while now and I am forced to ignore these errors and copy the problematic files manually.
I would appreciate any help and please let me know if further info is required.
BTW, really appreciate this awesome SW and your contribution!
Cannot move file ERROR_ALREADY_EXISTS
Let's have a look: https://freefilesync.org/faq.php#trace
Thank you Zenju!
I sent you the PML file.
Using the above as an example, E:\ArchiMED4\DBImages\10039774\DB1.SIM is deleted successfully, then a rename is attempted:
failing with ERROR_ALREADY_EXISTS.
So it's a netwerk server or driver bug. Obviously the file cache does not include the fact that the file was already deleted when it incorrectly fails with ERROR_ALREADY_EXISTS, so the network drive is violating sequential consistency.
We can try something: Overwrite the target unconditionally: https://www.mediafire.com/file/79gf315vdjbxccm/FreeFileSync_11.28_%255BBeta%255D_Windows_Setup%25287%2529.exe
Hi Zenju,
I tried the running the 11.28 BETA version and not I get the following error instead:
Cannot move file
"E:\ArchiMED4\DBImages\10039774\DB2~c6ef.ffs_tmp" to
"E:\ArchiMED4\DBImages\10039774\DB2.SIM".
Error code 0x571: The disk structure is corrupted and unreadable. [MoveFileEx]
After seeing this, performed Windows' "Error checking" for my drive and errors were indeed found and fixed.
I rolled back to FFS latest release 11.27 and ran the file sync and it worked perfectly!
Thank you so much for your help and your super useful SW!
Cannot move file
