Hi there,
When FFS tries to delete folders I get the following errors:
(I've blocked out some of the directory names for NDA reasons - there are no illegal characters in the actual directory name)
11:08:15 Warning The recycle bin is not available for "/Volumes/GoogleDrive/.shortcut-targets-by-id/1lepBbr6kJXMkanLjpgTKkm7wiQ4LCTBn/************************/Mix Engineer folder/EP0/ASSEMBLIES/EP0 PT RS".
CocoaError 3328: “EP0 PT RS” couldn’t be moved to the Bin because the volume “Google Drive” doesn’t have one. [NSFileManager::trashItemAtURL]
Ignore and delete permanently each time recycle bin is unavailable?
11:08:19 Warning Deleting folder "/Volumes/GoogleDrive/.shortcut-targets-by-id/1lepBbr6kJXMkanLjpgTKkm7wiQ4LCTBn/**************************/Mix Engineer folder/EP0/ASSEMBLIES/EP0 PT RS" [The recycle bin is not available]
Selecting permanently delete does not cure the problem.
Any ideas?
Thanks,
Rob
Google Drive - Deleting Folders/Files During Sync Error
