running separate syncs ON 2 DIFFERNT ext hdS
computerzpro
Hi:
Whenever I add a new synch configuration I loose the previous one...I try to run two synchs A daily one to one External HD & A Weekly one to another External HD so what is the best way to set up the two separate Synch?
Cheers
Daniel
Save each of your sync configurations from the FFS GUI as a *.ffs_gui-file (or *.ffs_batch-file) under a self-selected, preferably descriptive name via the File menu, or via one of the icons in the Configuration box (top left) in the FFS GUI.
Those will then show up as recent sync configurations, and can be selected from there, or by opening said file from the FFS GUI.
computerzpro
Ok, will try
Thank you
Daniel
