Syncing One Folder to 13 other folders?
Osinedges
I have one folder which contains multiple folders and files in each folder that I need to sync with the other 13 folders so that whatever is put into folder A gets synced to the other 13 exactly the same. However when I go to add folders it adds in pairs and it looks like when I press sync it's going to try and sync 1:1 on folder x > empty folder
Is this right or will this explode? haha
Really new to this software, I'm super confused, sorry if It's a dumb question.
Any help will be massively appreciated, thank you in advance!
You'll have to put the source location in all of those pairs, you can't leave them empty like that
Osinedges
You'll have to put the source location in all of those pairs, you can't leave them empty like that xCSxXenon, 25 Nov 2022, 15:29
Yeah this is my thinking, I don't want those folders to sync anywhere, I just want
the top left one folder to sync to the other 13
Folder 13 > Folder 1
Folder 13 > Folder 2
Folder 13 > Folder 3
Folder 13 > Folder 4 ... and so on.
I'm starting to think it's maybe not possible with this software?
EDIT: I am a fool, I've just realised what you meant by source folder. So my folder 13 needs to go all in the left there.... Damn I knew I was missing something...
And select "mirror". You probably don't want "two way".
