Raspberry Pi Version of FreeFileSync
toni2012berlin
Hello, is there anywhere a version of FreefileSync for
Raspberry Pi? (armhf or arm64 in DEB) for Raspbian or Ubuntu?
I could not find it!
Basil Rathbone
20 June 2023
Hello, is there any possibility a Raspberry Pi version of FreefileSync could be made available? (armhf or arm64 in DEB) for Raspbian or Ubuntu?
daviank
As per: https://repology.org/project/freefilesync/history
2023-02-09 07:03 Raspbian Testing has caught up with the newest version
By that time it was 12.0.
12.4 may arrive soon
gauthiec
Hello if you are still interested, i've just generated freefilesync 13.9 on a raspberry pi 5
and i can provide you with the binary: FreeFileSync_aarch64
dglad4
I'll grab it for my Pi 4, thanks gauthiec. I had a look at the generation process and got overwhelmed by how long it was, any tips or guides you can link so I can give it another go? Appreciate it!
gauthiec
Tell me a place where i'll be able to push it to you ....
gauthiec
dglad4
https://filebin.net would be fine, cheers!
I tried to compile myself but ended up with:
compilation terminated due to -Wfatal-errors.
make: *** [Makefile:128: /tmp/FreeFileSync_aarch64_Make/ffs/src/application.cpp.o] Error 1
I don't know enough to get it corrected, so an already built ARM package would suffice, thanks again
gauthiec
gauthiec
It's built with no google key, but it works well for local Sync !
albertage1231
hi, can you share it again? i too failed at compiling it :(
gauthiec
Hello, you can find it here:
https://filebin.net/zfglgv403e6dxf6l
albertage1231
got it,thank you soooo much, i'll try it out now!
