ERROR_IO_DEVICE possible due to crashed file transfers (large files)?
stefgers
OS: Windows 10
Networkdrive: Shared with Samba through Raspian
FFS: 11.28
I recently FFS-syncing crashed with errors:
ERROR_IO_DEVICE: The request could not be performed because of an I/O device error.
My question is:
Can a slow (even possibly interrupted) connection between a lokal drive and a "network drive" or "slow USB-drive" lead to a crash in FFS in that kind, that it breaks the filesystem?
Important to know:
• The Sync-Folders conaint large files with sizes >4GB.
• Network drive: That is an external harddrive to a RaspberryPi4 with NTFS-Filesystem which gets mounted by Samba to the network
Nope, there is an issue with a storage device, 99% guaranteed
stefgers
Nope, there is an issue with a storage device, 99% guaranteed xCSxXenon, 05 Dec 2022, 17:35
I followed the same idea at the 1st instance with the external harddrive at the RaspberryPi (that's my case: "slow network drive"). Filesystem-repair on the external harddrive was successfull. I tested it afterwards as ok and it is now in an error-free and daily use as backup drive for another ~10days. Which means, I can excluded an issue at the storage device.
I bought some new USB3.0 flash drives (3 pieces) to reproduce the case under the assumption of a "slow network connection" as root cause (this is the case I named "slow USB-drive"):
• I attached the flash drive to another Win10 maschine (an old 32bit ThinkPad-Laptop with USB2.0 only) and made it available throught network
• I ran into the same issue of a broken filesystem, but impossible to repair on both Win+Linux.
So what about the missing 1% in xCSxXenon's answer?
I would love to here on opinion on that before trying to reproduce with logfiles. That's time consuming because of the considerd large files and I'm risking another damaged flash drive. Please get me right, I would do that, if it is of help to prove reasonable ideas on the 1%.
Additional notes to avoid answers on other possible root causes I already considered:
• My "network" is wired with Gigabit wires and Switch.
• All considered devices (Windows Maschines and the RaspberryPI) are equipped with Gigabit network.
• OS-systems are all up-to-date and free of virus or malware.
• No other devices active in the network at occurance of the issue in both cases.
• No other processes active on both maschines in the case "slow USB-drive".
