Hey,
I am syncing more than 2TB from Gdrive to a local HDD. all went well but then I am stuck with 6GB files that won't sync and keeps on showing the error "is used by more than one item in the folder".
Note that I am running the sync on a fresh clean win11 install.
what could be the issue?
"is used by more than one item in the folder" Error
Thanks!
*Solved*
*Solved*
