Set default action by sync collision
lunzeitig
Hi.
Is it possible to set up default action when 2 entities are in collision? As I understand, if a file on both sites is changed, the dialog appears you to solve the issue. In my case one of the site is more prefffered. When the colision occurs the issue could be solved by "forced" overwriting by the file from preffered site. No admin action would not be needed.
When defining a Custom sync variant, you can select your preferred action (different from: "Leave as unresolved conflict") for the Difference category "Conflict/item can not be categorized".
