Visual improvement to Comparison using Local settings
OhBoy
The Compare button indicates Multiple...
Clicking on the toothwheel brings up the Synchronisation settings.
The All Folder pairs indicates File time and size.
As the Compare button indicated Multiple I know one or more folder pairs have a different setting.
Problem is there is no indication which folder pairs are affected.
Currently the only way I know is clicking on each one to see which one have a local setting.
This is a bit awkward if there are many folders.
Would it not be possible to either bold the folder or preceed it with an * or any other visual means to quickly indicate which folders have a local setting?
Just a thought
Each pair with local settings will light up that respective icon between the two folders in the list
OhBoy
Ahh, many thanks! Understand it now. I looked on the Comparison Setting screen whereas it shows it on the main screen. Just needed to scroll through the folder pair list.
All good now.
Many thanks
With that in mind, I have wished for some indicator to be present in the menus themself. It would be nice to know which pairs have local configs without leaving the settings or clicking through each pair
