RTS not working across linux share
theleetbeagle
I have RTS running a Two Way Sync on a Windows machine. Tried both mirror and Two Way.
One folder is local on the windows machine, syncing to a mapped drive shared on a linux machine.
The goal is to have any updates on the linux share immediately backed up to the windows machine.
When I update files on the linux machine from the linux machine, RTS isn't detecting them.
When I update the linux files FROM the windows machine, they're immediately detected.
Is there a limitation with network shares, or am I something I'm missing?
theleetbeagle
I got it with 15-second intervals on Task Scheduler. Now just wondering if it's a limitation of RTS.
Shouldn't be... What was the idle time before changing to 15 seconds?
theleetbeagle
Shouldn't be... What was the idle time before changing to 15 seconds? xCSxXenon, 15 Dec 2022, 19:44
I had it down to 2 seconds in RTS.
Interesting... I would have guess it was higher than 15, and maybe something was interacting with it before the idle time would be reached. I haven't heard of such limitations in FFS. Not sure what would cause that, but at least it is working I suppose. Is it feasible to lower the idle time to see when it cuts off again?
theleetbeagle
Shrug, idk. I'd edit a file with gedit on the linux machine and Save. RTS wouldn't catch it, no matter how long I waited.
If I edited that same file (or any) in notepad in Windows, and saved it, RTS would immediately catch it.
It's no big deal. I'm using Task Scheduler and it's working fine.
