Build failure on mipsel architecture (undefined reference to symbol '__atomic_load_8@@LIBATOMIC_1.0')
daviank
Hello Zenju & all,
I'm having this error when building freefilesync on mipsel architecture:
mkdir -p ../Build/Bin/
g++ -o ../Build/Bin/FreeFileSync /tmp/FreeFileSync_Make/ffs/src/application.cpp.o /tmp/FreeFileSync_Make/ffs/src/base_tools.cpp.o /tmp/FreeFileSync_Make/ffs/src/config.cpp.o /tmp/FreeFileSync_Make/ffs/src/ffs_paths.cpp.o /tmp/FreeFileSync_Make/ffs/src/icon_buffer.cpp.o /tmp/FreeFileSync_Make/ffs/src/localization.cpp.o /tmp/FreeFileSync_Make/ffs/src/log_file.cpp.o /tmp/FreeFileSync_Make/ffs/src/status_handler.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/algorithm.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/binary.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/comparison.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/db_file.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/dir_lock.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/file_hierarchy.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/icon_loader.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/parallel_scan.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/path_filter.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/speed_test.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/structures.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/synchronization.cpp.o /tmp/FreeFileSync_Make/ffs/src/base/versioning.cpp.o /tmp/FreeFileSync_Make/ffs/src/afs/abstract.cpp.o /tmp/FreeFileSync_Make/ffs/src/afs/concrete.cpp.o /tmp/FreeFileSync_Make/ffs/src/afs/ftp.cpp.o /tmp/FreeFileSync_Make/ffs/src/afs/gdrive.cpp.o /tmp/FreeFileSync_Make/ffs/src/afs/init_curl_libssh2.cpp.o /tmp/FreeFileSync_Make/ffs/src/afs/native.cpp.o /tmp/FreeFileSync_Make/ffs/src/afs/sftp.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/batch_config.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/abstract_folder_picker.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/batch_status_handler.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/cfg_grid.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/command_box.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/folder_history_box.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/folder_selector.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/file_grid.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/file_view.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/log_panel.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/tree_grid.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/gui_generated.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/gui_status_handler.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/main_dlg.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/progress_indicator.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/search_grid.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/small_dlgs.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/sync_cfg.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/tray_icon.cpp.o /tmp/FreeFileSync_Make/ffs/src/ui/triple_splitter.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../libcurl/curl_wrap.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/file_access.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/file_io.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/file_path.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/file_traverser.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/http.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/zstring.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/format_unit.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/legacy_compiler.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/open_ssl.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/process_priority.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/recycler.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/resolve_path.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/process_exec.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/shutdown.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/sys_error.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/sys_info.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/sys_version.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/thread.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../zen/zlib_wrap.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../wx+/file_drop.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../wx+/grid.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../wx+/image_tools.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../wx+/graph.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../wx+/taskbar.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../wx+/tooltip.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../wx+/image_resources.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../wx+/popup_dlg.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../wx+/popup_dlg_generated.cpp.o /tmp/FreeFileSync_Make/ffs/src/../../xBRZ/src/xbrz.cpp.o -Wl,-z,relro -Wl,-z,now `wx-config --version=3.2 --libs std, aui, richtext --debug=no` -pthread -lz `pkg-config --libs   openssl` `pkg-config --libs   libcurl` `pkg-config --libs   libssh2` `pkg-config --libs   gtk+-3.0` `pkg-config --libs libselinux`
/usr/bin/ld: /tmp/FreeFileSync_Make/ffs/src/base/comparison.cpp.o: undefined reference to symbol '__atomic_load_8@@LIBATOMIC_1.0'
/usr/bin/ld: /usr/lib/mipsel-linux-gnu/libatomic.so.1: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[1]: *** [Makefile:135: ../Build/Bin/FreeFileSync] Error 1
make[1]: Leaving directory '/<<PKGBUILDDIR>>/FreeFileSync/Source'
dh_auto_build: error: cd FreeFileSync/Source && make -j4 "INSTALL=install --strip-program=true" returned exit code 2
Could you please help? How can I fix this?
daviank
Looks like this one can be fixed by adding -latomic to the LDFLAGS on mipsel architecture.
Not sure if this is the correct way to fix this though.
bgstack15
Not an expert either, but if merely linking to an additional library gets you want you need, it sounds fine. There's probably a set of default libraries that are always linked to, and that list of defaults is probably different for each compiler * compiler version * architecture * distro!
