Disable RTS finished dialog+sound
jkister
I'm using the portable windows version of FFS/RTS. I created the ffs_batch, used it in RTS, and saved the ffs_real.
All works using RTS with the ffs_real, but when it's done syncing there's a dialog window that pops up and it plays the bell sound.
How can i disable the window+bell sound ?
It sounds like you didn't check 'auto-close' when you saved the ffs_batch configuration
