So i have a M1 MacBook Ventura OS at home and a win 10 machine at work, both have the latest version 11.29 Sync donation edition. Recently it feels like since v11.24 my mac has slowed down tremendously scanning and writing but mostly on the scan. the performance settings/options on each are set the same for parallel operations. the scan on the PC takes a couple seconds and on my Mac its closer to a minute or two for the same file count and set.
Any ideas?
Mac M1 sync used to fast now slow?
Can you also confirm this via performance tests between v11.24 and v11.29?it feels Lee, 29 Dec 2022, 19:35
I have gone back to multiple versions including back to 11.19 I believe and it was still slow to scan. May it be something with Mac OS Ventura ?
How can I do a performance test?
