Recently I am getting error message saying can't find the recycle bin, it's always worked in the past.
I have noticed that people are saying to use the "permanent" option.
If this is the new way to delete, it would help if the option for the recycle bin is removed in the next update to stop use thinking there is a problem.
Recycle bin missing
Using the recycle bin is still possible, so the option needs to stay, it's just not working for you anymore.
Looks like it was working but now FFS can't find where the recycle bin is, as if it was renamed/moved.
