compare only by time
gilad.narkis@wdc.com
Is there a way to compare files only by time?
we have files that change by size but not by time, and we need to have this option.
maybe its already there, but I couldn't find it.
Thx
please have a look on the attachment please have a look on the attachment
Not an option. You can set up a custom sync and tell FFS what to do if there is a conflict such as that though. But FFS sees that as two files that were updated individually and can't know which one is the better one to keep
therube
/Your/ earlier thread, viewtopic.php?t=9884.
therube
While slower, wouldn't a Content compare ignore time?
And at the same time, it would be more accurate then simply a Size comparison (as the size may be the same, & the date /is/ the same, but the content could be different).
That is true. Content compare should work, but it is incredibly slow from my memory
