Hy from Italy.
As you can see in the attached file, there is an error in the Globalsetting.xml and j cannot understand where is the problem.
Can you please help me ?
Thank you.
Error GlobalSetting.xml
The XML is missing the 'version="1.0" attribute'. I'll add it back for FFS 11.30.
Thank you. May be that's why J cannon more scheduled my job in my Mac Ventura ? When J save the batch job in Automator and save my scheduled app, the calendar don't start automatically like has always made with the latest version .
You could test.
Backup GlobalSettings.xml.
Edit GlobalSettings.xml with a text editor.
Change
<?xml encoding="utf-8"?>
To
<?xml version="1.0" encoding="utf-8"?>
& see if that gets your scheduled job working?
Change
To
Hy, and thank you for your professional help . Solved the problem concerning the error of the Globalsetting.xml but when J save the batch job in Automator and save my scheduled app, the calendar don't start automatically like has always made with the latest version . J have tryed more times but don't work. Have a nice day
