Greetings,
I would like to see which file or directory has triggered a synchronization.
In the RealTimeSync documentation I've noticed that on Windows there's an option to do that using the %change_action% variable, but it's not available on Linux.
Is there any way to know what caused a change on Linux?
RealTimeSync see what triggered a change on Linux
The syntax ist basically the same. I've updated the manual:
https://freefilesync.org/manual.php?topic=realtimesync
Thank you for the quick response,
I was confused as to where these variables are available and that it was actually in the RealTimeSync's command line field, not in the terminal itself.
If I may, I would suggest adding this to the manual.
