I want to sync all of c:\Users\jlk except for the file c:\Users\jlk\AppData
Adding \AppData\ to the EXCLUDE list does not do it.
Not sync a sub-folder
The programs interprets phrases ending with "\" as folder names. So remove the
trainling backslash.
Sorry, I meant folder, not file. AppData is a System folder; trying to back it
up causes all kinds of problems. JLK is a folder created by the system for all
files belonging to the user whose name is JLK.
I also tried to add: **\AppData\ to the exclude list, as well as: AppData\ No
joy!
joy!
Excluding "\appdata\" should do the job, just tested it. Could you send me
your configuration, so that I check where the problem is?
What did you want me to send? Do I run a program? I use Windows 7 prof. on a
Dell 620. Has 2 GB of Ram.
Please wait on this. I found a space in one of my attempts. Maybe it will work
now.
now.
