recycle bin error
lt72884
I did search and i think i have the same error as others. Its just worded differently.
The recycle bin is not available for "sftp://user@x.x.x.x/School files only".
Operation not supported by device.
Ignore and delete permanently each time recycle bin is unavailable?
My ssh server is an older windows xp box with SP3 on it. this is just for testing purposes.
I am only using mirror option to send data from my desktop to the ssh server. If i delete a file on the desktop folder, will it be able to delete from the server? or whats the best option to do?
The folder on my desktop named "school files" is CONSTANTLY (except while sleeping haha) changing with either adding folders, removing files, adding word docs, edit excel files, edit word docs, every single day.
I will be having a scheduler run the batch file each night around 11:59PM to make any changes needed to the ssh server via ffs_batch.
I currently use sync-thing between my laptop and desktop so that my laptop and desktop are in constant communication for my school files:)
thanks
lt72884
ok, great, thanks. I figured it was something to do with how the 1TB drive has no options for the trash bin.
So far this program is exactly what i have needed. I tried to get duplicacy up and running, but i am having some major issues with it.
for now, this free file sync works great
