I get the following message when using the mirror function in the Donation Edition of the Software (also present in the non-donation edition)
Is there a way for me to get FreeFileSync to work with my Samsung phone?
Hopefully, this can also help others who may be struggling with this issue.
MTP Samsung Unable to Delete Files
This is a just warning.
If you continue, FFS will perform as intended, except for moving deleted files on your phone to a recycle-bin. Instead those files will then be permanently deleted.
I have tried this. However, the file is stuck being "deleted" foreverThis is a just warning.
If you continue, FFS will perform as intended, except for moving deleted files on your phone to a recycle-bin. Instead those files will then be permanently deleted. Plerry, 19 Jan 2023, 10:13
