the progress screen of FreeFileSync
When RealTimeSync is running, the progress screen of FreeFileSync is now displayed due to a file change. This was not the case before. Is this due to a version change? Or is it because of my settings?
If you go back to the previous version, does it return to normal?
It has not changed for me, so I would be inclined to blame settings.
Thaks for your reply.
Do you know how to get the previous version?
Dear xCSxXenon,
Thanks for your help.
I have changed FeeFileSync back to 11.29 and I get the same problem (I am using the current version of RealTimeSync). If you can suggest which setting is the cause, please let me know.
Re-save your .ffs_batch configuration and make sure you checkmark the 'Run minimized" box
