Hey,
I have been running this for many years without any issues.
Now on linux arch, mint, kubuntu, manjaro, reborn, none of them work!
Clean installs even building it from scratch.
The new build is broken. I have no idea what to provide for information.
12.1 broken
Most likely viewtopic.php?t=10103
Thanks for the reply.
I have tried the 12.1 version with the same issue. I am in plasma 5.27 on arch 6.2 zen kernel. Amd system with integrated graphics.
I have reverted back to an older version and it works fine.
The application opens, I can access the settings but when I try to sync anything, nothing happens.
I hope you guys resolved the issues soon. Thanks
I found a solution I want to share with you guys
I can now build 12.1 successfully and it works just fine
In order for this to work, I needed to enable 32 bit and multilib support in /etc/pacman.cofig
Now the bin file can be compiled and works just fine
Maybe this is the issue with the new builds in general?
I hope this helps people!
